Intermittent heat
162 Views 2 Replies 3 Participants Last post by  YoshiMan38
Hello!!!!
Heat works for a few mins, then blows cold. I can turn it up to the highest setting, same result.
Has anyone experienced this???
06 RTL
1 - 3 of 3 Posts
I've had it happen on a Ford - it was a $30 "Evaporator Air Discharge Temperature Sensor"
Have you checked your coolant levels? Usually if they run low, the heater core will be the first thing to loose coolant flow, hense why there may be no heat.
1 - 3 of 3 Posts
