Some background and the problem:
So not too long ago I had the timing belt done, water pump serpentine tensioner, timing belt tensioner done by the Dealership for 700. I figured I would do the differential oil change and transfer case oil change later. So some things I noticed...when draining the transfer case oil (which I used the Valvoline 80-90W GL4-GL5 Hypoid gear oil) Draining the old fluid it was a super bright red color. I know it's the transfer case and not the tranny, because takes just under a Qt to fill it up + it's location. The replacement fluid is a near yellow oil color. I performed the VTM differential fluid change as well since I was a little behind on that because it started to sound a little noisy whine related to my speeds. I have 103k miles on my RL. Now the issue at hand which is intermittent sounds like a faint (can only hear it when the radio is off) short grinding or clicking when coming up my hill to my house that lasts for about 2-3 seconds. It is not steep, like a gradual 1-3% grade over 1 mile seems to be at the same spot in the road every time. I haven't had it happen when driving around town or back country roads, etc...The other sign I noticed is when in a parking lot going over a steep speed bump the yellow triangle with the exclamation blinks for a few seconds indicating traction control/stability assist. I don't drive fast over the speed bumps but thought it a bit weird...I recently drive the truck a lot more and it used to sit for days on end when I had a company car if that information helps...I noticed I need to also flush my brake fluid because it is looking pretty dark and was last done a few years ago, and I'll probably get to it next week.
Any ideas, or things to watch out for in this situation? I have no error codes, incomplete codes, or any hard faults.
Thanks in advance.
Thanks in advance.
