I have a 2006 Honda Ridgeline RTS with 176,XXX miles on it. I bought the truck in May and noticed it took just a touch longer to start than most vehicles I had driven but didn't think anything of it. Recently I have noticed not only a dramatic decrease in mileage (used to get 15-17 around town, now down to 12-14) but also that sometimes the truck barely starts! The remote starter will not start it after 3-4 tries, and when turning the key physically it will crank for 25-30 seconds before catching and starting up.
The mileage is NOT due to the cold weather, as this began prior to the temperature fluctuations here in Boston. I always fill up at Top Tier stations, but have switched it up every so often to see if it helps the mileage. I have also tried using premium and it has not helped.
The dealership inspection turned up nothing, the ECU is throwing no codes.
Recent work includes...
- Timing belt replacement
- Brake Inspection
- Removal/Inspection of Fuel Pump and Cleaned Filter
- Transmission Fluid Change
- Engine Oil change every 5-7k w/ Mobile1 Synthetic
- VTM-4 Fluid Change
- Injector Compression Test (Holds Fine)
- Spark Plug(s) Replacement
- Alignment/Balancing of tires
- Intake/Exhaust Valve Adjustment
- Water Pump Replacement
- Air filter replacement w/ K&N washable
