1 - 3 of 3 Posts
Hey folks just purchased a previously enjoyed inverter Ac Inverter OEM 09 10 12 13 14 Honda Ridgeline P/n: 38500-SJC-A01 R321239
the problem is I have not found ANYWHERE for coupling together a NEW PLUG to go into the inverter. The old one is in bad shape and I haven't found anywhere where I can order a new one to splice in. I've attached two pictures to explain what I'm looking to try and replace
Is this inverter a standard piece of equipment or an accessory? I'm not familiar with the issue other than seeing the melted connector.
It's part of the existing wire that supplies power, ground and most likely wires that feed into the power power outlet in the center console. The inverter is mounted undder the front passenger seat. I'm sure the female plug is part of the entire wire harness. I assumed I could have found just a new female plug that I would replace the old one with.
1 - 3 of 3 Posts
