I'm not sure what section to post this in (mods- move it if you think it should go elsewhere).
I've searched and haven't come across anything that specifically addresses my question (wrong search terms?) plus I bought truck used so owner's manual is missing.
Anyways, I think the battery on my fob is on its way out. Sometimes it takes a few presses of the button to lock/unlock the truck and it seems the range is getting shorter and shorter. Simple, replace the battery CR1616 , careful - don't strip the screw to relive the cover, etc..... , but Im not clear if I need to reprogram anything to get it to work. Assuming that since I haven't come across any info on this particular question, that it is just a plain
and simple battery replacement? I just want to make sure so, somebody correct me if I'm wrong.
I'm probably overthinking this but I just want to avoid the hassles of putzing around in below freezing temps programming anything.
