Last September, I was able to place an order for a set of KW V3 coilover shocks and after waiting for almost 2 months, I got the massive package from Germany on October 26th. I placed the order through AutoAnything.com, who is one of the authorized dealers (you need an authorized dealer for your warranty) for around $2400 before taxes. [ Authorized dealers can be found here >> https://www.kwsuspensions.com/dealersearch ]
Note: Anytime someone modifies their engine with non OEM accessory, they assume the risk of voiding their vehicle's mfgr's warranty and possibly damaging the vehicle if proper care is not taken. By following these suggestions, you are at your own risk as I do not assume responsibility of your install.
Difficulty: Intermediate
Time: 6 to 7 hours (took me around 5.5 hrs)
Parts needed & replaced
Some of the tools you may need
Access to a two or a four post lift would save your back and reduce the project time, however it is not necessary. Luckily my colleague has one in her house and I was able to use it. One person can do this project, if you are mechanically inclined. Not having pneumatic tools or power tools should not be a deterrent. I used my hands for 99% of the work and used a cordless drill to unscrew or screw in bolts and nuts. I highly recommend liberal use of rust penetrant and using a breaker bar to unseat fasteners.
IMPORTANT: ensure that you have access to Honda Factory Service Manual for your Ridgeline. Read and fully understand KW’s instruction manuals.
- Front adjustable camber bolts AC Delco 45K18039 - $10.20 x 2.Qty
- Front Left LCA Mevoteech GS601014 - $64.99 (SummitRacing.com)
- Front Right LCA Mevotech GS601015 - $58.99 (SummitRacing.com)
- Front Strut Mount Monroe 907983 - $28.79 x 2.Qty (RockAuto)
- KW V3 Coilover shocks – $2550.06 (AutoAnything.com)
- Rear DR End link ACDelco 45G1045 - $17.82 (Amazon)
- Rear PA End link ACDelco 45G1987 - $12.73 (Amazon)
- Rear Strut Mount – Monroe 902044 – $28.79 x 2.Qty (Rock Auto)
- Rear Upper Control Arms-Adjustable Centric 622.40095 – $59.96 x 2.Qty (CariD.com)
- ½” and 3/8” socket wrench
- ½” Torque wrench
- Assorted screw bits
- Assorted extensions
- Assorted screwdrivers
- Assorted sockets
- Assorted swivel joints
- Assorted wrenches/ratcheting wrenches
- Ball joint separator
- Bench vice/vice
- Crowfoot wrench sockets
- Digital caliper
- Digital inclinometer (to determine OEM camber and rear upper control arm angle)
- Electrical tape
- Hammer (optional)
- Impact wrench (optional)
- Pry bar (assorted)
- Punch (center punch or a dull screwdriver)
- Rust Penetrating spray
- Transmission stand (optional)
- Zip ties
