Looks like this installation video is on a Pilot
Looks like it's available again.This is the 70” one I bought. It’s out of stock right now though. Perfect length.
Wont receive until end of January. Definitely coming from China.Looks like it's available again.
I saw an ad for the Silverholder hood light strip and decided to try it out. I bought the dynamic white one that zig zags across the front before fully lighting. The strip was easy to install and looks good but there are zero instructions included. The trick is to locate a switched power source…all of the fuses tested hot when the truck was turned off so I tied it into the driver’s side headlight. I may have also been able to connect it to one of the relays in the fuse box. It looks good with my LED fog lights. Sorry for the crappy pictures.
View attachment 432603 View attachment 432604 View attachment 432605 View attachment 432606
do you remember what color wit you used from the headlightsI saw an ad for the Silverholder hood light strip and decided to try it out. I bought the dynamic white one that zig zags across the front before fully lighting. The strip was easy to install and looks good but there are zero instructions included. The trick is to locate a switched power source…all of the fuses tested hot when the truck was turned off so I tied it into the driver’s side headlight. I may have also been able to connect it to one of the relays in the fuse box. It looks good with my LED fog lights. Sorry for the crappy pictures.
White, after it criss crosses on startup it stays solid whitedo you remember what color wit you used from the headlights
Thanks I've been trying to research were to tap in to my vehicle.I saw an ad for the Silverholder hood light strip and decided to try it out. I bought the dynamic white one that zig zags across the front before fully lighting. The strip was easy to install and looks good but there are zero instructions included. The trick is to locate a switched power source…all of the fuses tested hot when the truck was turned off so I tied it into the driver’s side headlight. I may have also been able to connect it to one of the relays in the fuse box. It looks good with my LED fog lights. Sorry for the crappy pictures.
