1 - 11 of 11 Posts
Last night I noticed that the LED indicator light on my Cruise Control Button was not on. The Cruise Control was activated and working, but the LED was not on.
Tried to do a search here, but "LED" is too short for the search routine, and did not find anything similar on "light".
Has anyone else run into this issue?
DoctorJ said:
I don't recall anyone with the same problem. However if its an LED then its unlikely it burned out and it may just be a loose wire on the switch.
I agree since the life expectancy of a LED is near forever.
I probably should have mentioned that I am an Electrical Engineer, and that much of my career has been in Reliability Engineering and Failure Analysis Engineering.
I fully agree with the comment on the expected life of a LED. Not knowing the exact sytle utilized, I can only make a "guess-timate" (based on experience) of the probability the LED actually failed of ~0.2%.
Was curious if anyone else had this happen.
No issues here and I keep the button on whenever I'm driving. It's not in the easiest access position so why even turn it off?
As another EE, I agree.
Yes, I too noticed that the green light on my cruise control switch is no longer working, along with a few other accessory lights. Im trying to troubleshoot the problem with no good results.
And hence the problem when too many electrical engineers group into one solidarity movement and decide unanimously on a final verdict. :p
Unfortunately, it takes a mechanical engineer to explain to you guys that by simply removing the switch (both a mechanical as well as an electrical action), the light bulb can be replaced for under $5.00. ;) :D
I had a cruise control light bulb burn out when the RL was about a year old. But being just an M.E., I had it replaced under warranty when I was at the dealer for an oil change. :D
It wouldn't bother me if mine was to burn out. Too bright at night. A piece of tape solves the problem.
It's an incandescent light bulb rather than an LED. So far, all my lights still work at 10,000 miles, but my buddy's 30K-mile '06 has bulbs burned out for VTM-4, SELECT, RESET, and DOOR switches. (Those are just the ones I've noticed - there may be more). I'll be glad when incandescents are gone from the automotive industry!
1 - 11 of 11 Posts
