When I installed my Truxx lift kit four years ago, it came with extended front sway bar links. The rear section of the lift used the OEM links. I thought I remembered reading that the extended links that came with the lift kit were actually the exact same length as OEM Pilot links. Can anyone confirm this?
I have low speed clunking under the truck that I cannot pinpoint but after some pretty extensive research I'm thinking it's either the shocks/struts or the swaybar links. The noise is driving me insane. Truxx wants $118 for a new set of extended front end links while I can get OEM Pilot links for around $20/each. So any help would be greatly appreciated.
