1 - 3 of 3 Posts
For those of you with the lighted running boards, could you please enlighten (LOL) the rest of us as to when they are illuminated. It seems like it would be quite easy to tap/plug into their power source for use with alternative lighting.
They come on when you touch the door handle. Not sure how long they stay on when you exit but seem like 5-10 seconds. I will time it tonight if someone else does not answer first.
The lighted running boards are linked to the interior light circuit, so they will do whatever you have your interior lights set to.
Example: If you have your interior lights set to run 30 seconds after vehicle departure, the boards will stay on for 30 seconds also, and will "fade" off just like the interior lights.
The blue Ridgeline light up sills also run on this circuit, and share the same accessory harness.
So if you are considering the Ridgeline sills and the lighted boards, do them at the same time as both share the same interior removal sequence for installation.
1 - 3 of 3 Posts
