Let us know when you get an official diagnosis. This thread is for transmission failures - it's possible you have a torque converter failure (almost as bad) or pressure switch failure (not nearly as bad).Add me to the list!
2017 RTL AWD 69,570 miles and "transmission system problem" light appears.
This post has me wondering about TC replacement. I have a 2017 with 83k occasionally showing the Transmission System problem warning, but no apparent transmission issues. Dealer just told me they believe it need a new TC. So the million dollar question, is replacing the TC indiciative of eventual trans failure? Should I repair it, or just do a multiple dump-n-fill, and sell the RL?Thanks for the links @zroger73 and insight @Kevo
I see no post yet that mirrors the issue I had. I never had any tranny shifting problems ever. It shifts perfectly.... before and after the convertor replacement. No error code at all if driving around town in lower gears or leaving it in 4th on the highway. No judder of any kind. Diagnosis concluded I didn't need the shudder TSB done or so the paperwork said. There's about 100 miles on the repair. I can see it lock into 6th now. It didn't before. It hung around 2K rpm at 55 mph...then the error message would set after 10 miles or so. Every start cycle was a new time
I'm wondering if anyone had a similar problem No shifting issues, but a PO741 code...had the TQ convertor replaced only to have to do the tranny later on? I'm wondering if the convertor is a harbinger for further tranny trouble? Or is it possible the convertor fixed me? Also....there was zero contamination in my tranny fluid when they drained it. I had pulled the dipstick early on...before it went in. Smelled just fine and the color was just very slightly darker than new
I also realize that there are 1000s of these trannys that have never had an issue.
You need to decide that, but if I had to pay out $2K+ for a new TC with a real risk of a trans replacement later, I'd be looking to trade, unless you have Honda Care coverage for the next few years.Should I repair it, or just do a multiple dump-n-fill, and sell the RL?
Timing belt is coming up, your trade in value is high. If the trans fix is on your dime I'd trade it.This post has me wondering about TC replacement. I have a 2017 with 83k occasionally showing the Transmission System problem warning, but no apparent transmission issues. Dealer just told me they believe it need a new TC. So the million dollar question, is replacing the TC indiciative of eventual trans failure? Should I repair it, or just do a multiple dump-n-fill, and sell the RL?
Have you decided what you're going to do? Replace the transmission? Sell/trade the vehicle while it's still moving under its own power? Something else?Add me to the list. Approx 101k miles on my 2018 RTL-E. I've noted a hard shift from 5-6th the last ~2k miles or so, no dashboard lights or indicators. If I'm easy on the gas pedal things shift smoothly but not so under normal or hard acceleration. Was at the dealer for routine oil change & tire rotation today and asked the tech to look at it. He confirmed the hard shift and said lower gears are starting to exhibit hard shifts but they're not very noticeable yet to me. He searched his database and said out of 30 reported failures a replacement shift valve only fixed one of them. All but that one were finally fixed with a replaced tranny. Quoted me $8600, parts and labor.
Thats what I did. 18 RTLE AWD trans replaced at 42k under warranty, and at 58k traded for a 22 RTLE.As far as I have seen, only one user has reported that their replacement transmission was replaced again (after 12k miles). With that being said, I would not be surprised if most folks that had the trans replaced got rid of the truck altogether after that.
Going to be pretty difficult to know for sure, but my thought would be if you have your trans replaced, you are in theory getting a rebuilt trans with the latest revisions and is hopefully more reliable. I think it was estimated previously in this thread that a guess is an initial failure rate of 2-3%. With that, the likelihood that you would be one of the 3 out of 100 that has a failure and then get a reman that also failed is quite small, but clearly not impossible. The other factor is if yours gets replaced, you also have to trust that whomever replaced it did a good job.
If I ended up having to have mine replaced, I think I would be more inclined to trade it in. Then again, it would also depend on what the vehicle market is like.
If a Honda part number ends in "RM", that means the part is remanufactured.The part number they referenced for the replacement they used is for a new, genuine Honda transmission, not a rebuilt unit. You can see it here:
Honda 06200-5J8-305RM
