321 - 329 of 329 Posts
Ah, and this part does have RM, and so it is a reman. Thanks for pointing this out.
My G1 Ridgeline trans was replaced under warranty too (due to a whine since new). I also got a reman. AFAIK, that's all you can get as a warranty replacement.
Discussion Starter · #323 ·
Production of new 6-speed Honda transmissions ended about two years ago when 2020 Pilot production ended so there will be no new replacements going forward - they'll all be remanufactured.
Even when a transmission is still in production, a remanufactured unit will be shipped unless there are none available at the time in which case a new production unit will be shipped.
2018 RIDGELINE - BLACK EDITION
I have my 2018 Black Edition Ridgeline at the dealer for a new transmission. Luckily 41,000 miles and still under warranty. Dash lights came on after a 3 hour drive. 3 days to install. Saw the new 22 Ridgeline. The front grill got sunken in and looks weird.
Discussion Starter · #325 ·
#49
I just bought my first Honda: a 2018 RTL-T. You can add this vehicle to the list of 6-speed Ridgelines that needed to have the transmission replaced - the previous owner dealt with this. I discovered this by looking at the list of service records at owners.honda.com after I registered, and this is what the servicing Honda dealer recorded at 60,892 miles:
60892 TEST DROVE. CONFIRMED HARD SHIFT & SLAM INTO GEAR CONDITION PRESENT. REPLACED TORQUE CONVERTER DUE TO TCC NOT ENGAGING OR DISENGAGING PROPERLY. TEST DROVE AFTER TORQUE CONVERTER R&R. HARD SHIFT STILL PRESENT AND WOULD NOT SHIFT INTO PASSING GEAR. REMOVED & REPLACED TRANSMISSION ASSEMBLY DUE TO INTERNAL TRANS FAILURE. GOODWILL ASSISTANCE PER DPSM 75% CUSTOMER TO PAY 25%
Notice that it occurred 892 miles after the original drive train warranty expired. I'm sure that the previous owner was not happy to have to pay 25% of the cost, and doubtless this is why this truck came up for sale about two weeks later. The part number they referenced for the replacement they used is for a new, genuine Honda transmission, not a rebuilt unit. You can see it here:
Honda 06200-5J8-305RM
In poking through hondapartsnow.com, it appears that there were at least four previous Ridgeline transmissions that were discontinued:
Honda Ridgeline Transmission Assembly
I don't know if that means the transmission I have is an updated version or whether it will be more, less, or as reliable as the original transmission. Of course, I did not know about this until after I bought the vehicle. I've scoured the ROC forums and am familiar with what has been recommended, and I hope this tranny lasts a long time, but it is clear that one cannot predict with confidence.
#50
2017 RTL-E
I guess since no one has found the transmission VIN plate missing on their replaced transmissions, mine must have been from a junkyard since I have no VIN plate on my transmission. The remnants of the snap off bolts are there, but no plate.
Only the previous owner of my truck knows for sure.
I haven't gone looking for the tranny VIN plate. 🤷‍♂️
2019 Sport Lunar Silver
Doubtful your trans is original. They are removed on remanufactured trans.
2017 RTL-E
Some on here are saying there is a VIN with RM after the numbers.
Oh well, it shifts fine so I will change the fluid after 15K (the dealership changed it before I bought it).
