I thought about starting a list of
injector failures as well, but that would take a lot more time than I'm willing to put into searching and organizing.
#1
@Travis Hannigan
October 4, 2017
2017 AWD 13,600 miles
Whine, bearing failure
I have a 2017 AWD Ridgeline with 13,600 miles on it. I heard a wining noise coming from the transmission so I brought it back to the dealer. They said that there was a bearing failure. I've never pulled anything heavy with this truck. Has anyone had this problem with theirs?
www.ridgelineownersclub.com
#2
@jakerex
October 17, 2019
2017 with 58,000 miles
Fluctuating RPM
Around 1.5 - 2 grand when cruising I’m getting a jutter that makes my RPMs jitter up and down quickly. Sometime sit feels as if it’s starving for gas....like a partially clogged fuel filter. Any ideas? 2017 RL Sport AWD. 58k miles Sent from my iPhone using Tapatalk
#3
@mumbles
October 26, 2019
2018 with 11,600 km (7,200 miles)
Whine when idling
January 2018 build, Jan 2019 purchase, 11600km ( 7200 miles ) whining noise noticed when idling. 6 hrs in Honda with 5 techs, new trans ordered, about 1.2 days labour. Must admit bit disappointed, but life goes on......
#4
@asondica
October 27, 2019
2017 Black Edition
“20-60 kmh thudding, rumble strip feeling”
I've used the S-VCM for about 20K of my 30K total miles before my tranny developed a judder. I removed it before bringing it in for service. I believe I'm experiencing a bit of vibration at idle with it removed. I'm going to re-install it and see if it disappears.
#5
@jakerex
October 28, 2019
2017 Sport
Judder and “Transmission System Problem” message
#6
@JJkroch
January 9, 2020
2019 RTL-E with 18,000 miles
Unexpected downshift, flaring, harsh shifting
Issues today with my 19 RTL-E. First I have a long driveway 1200 feet. Driving up slowly, the RL downshifts. Weird. Let off the gas and back on and no issues. Top speed on my driveway is 10 at the most. Pull on main road and accelerate, hit 40 and it is like I shift in to neutral. Engine races...
#7
@zroger73
February 1, 2020
2019 RTL-E 14,000 miles
Transmission fluid pump failed
Yesterday while backing out of my parking space at work, my transmission sounded like a manual with straight cut reverse gears. I discovered that it makes the same noise when reviving the engine in park or neutral, although not as loud. The symptoms suggest a failing pump, but it doesn't do it...
#8
@robertnisivocci
March 12, 2020
2017 with 64,000 miles
“D4 transmission warning”
Purchased my 2017 in August 2017. Since that time. Passenger seat had to be removed for Air Bag sensor fix. Battery replaced after 1 year. Back up camera wiring harness broke ( no camera). ALL fuel injectors were replaced at 53k miles. NOW I got a D4 transmission warning. Trans probably...
#9
@RM8900
March 27, 2020
2018 RTL-E with 63,000 miles
How many 2018 Ridgeline transmission fail at 74,000 miles? $7000. It is only two years old. My 2006 Ridgeline has 225,000 miles on it, no problems.
#10
@mississauga145
April 24, 2020
2017 with 110,000 km (68,351 miles)
Harsh 1-2 shift, metal shavings in fluid
#11
@kbmandms18
June 21, 2020
2017 with 32,000 miles
Fluttering noise and vibration
#12
@ktm520
July 3, 2020
2017 with 45,000 miles
I thought about starting a list of injector failures as well, but that would take a lot more time than I'm willing to put into searching and organizing. #1 @Travis Hannigan October 4, 2017 2017 AWD 13,600 miles Whine, bearing failure...
UPDATE 7/4/20: To keep this original post from getting too long, I'm now adding the failures as additional posts.
