Hey Maxo.... share the link you found for your alternator swap.
No link found... I use the manual and found out it was quite easy... Took me about 45 mins in the cold outside... I can share some cues that aren't mentionned in the manual...
Since there's not much room to slack the belt, Honda use a special tool but with 2 long keys (14mm for the pulley) hook togheter you can work your way there...
An other thing thet is not mentioned is how to get the alternator out of there since it's quite tight there. The a/c hose is in the way... First, to make that step easier, you better take off the little bracket that sit on top of the alternator (the one that hold the 2 wires). Get the alternator loose by pulling it toward you and not pulling it aside like in the book... Finally work your way by pulling the alternator up with the pulley facing you. Mine came out that way...
Finally, put the new alternator in place and then reinstall the bracket on the alternator but don't tied it up at that point. Put the 2 bolt that hold the alternator in place then tight up the 3 bolts to position the alternator correctly.
Finish to hook up the wire, double check the bolts, make sure your belt is set correctly replug the battery and your good to go!
