Wow. The quality control hits from Alabama keep on coming.....
The service rep said that is how they found the loose bolt by wrenching each one until they found one they could tighten. He indicated the bolt wasn't loose just not tight enough.Do you guys know which bolt was loose?
Went through my trucks rear suspension, using just box end wrenches. I am moving, so the torque wrenches are packed and time at a premium. Towing a vehicle Monday. What I found was the only bolt that moved was the right lower rear bolt on the lower control arm. Not saying it was not in spec, but it was the only one that moved when I put the wrench to it. Not something I would want to come loose towing a car hauling trailer through the mountains. I don't think it was that kind of loose.
