Hmmmm, not sure about that. It doesn't have any openings so you would not be able to get a nut on the inside to secure a mounting bolt. Maybe if you had a mounting plate you could hot glue to the guard and use some screws too it might hold. Or you could cut a finger hole on the bottom to get a nut on the inside. At any rate it's thin plastic so I'd suggest a mounting plate of some sort, something more than just a bolt and washer.hondacop said:My bad! I was refering to the "brush guard".
I was wondering if , with a little extra support, a set of "off road" lights could be mounted either above or below the upper "bar". It looks like the wiring could be hidden inside.![]()
I am open to opinions and suggestions!
It's mirrored chrome.tlaudio said:Is the top part of the Lower Trim (Brush guard) chrome or does it perfectly match the roof rack silver?
TIA
TL
