Thanks oh six.. I've been looking at other tweeters like CDT, seas, sundown,and rainbow. a lot of them do not supply crossovers.. Is there a reason why companies won't sell crossover with tweeters.. I know I could make my own up, but I feel safer with 1 from manufacturer...
Danger! Spewage follows! :act024:
For the most part, band limited speakers sold independent of crossovers and mating components are intended for use by intermediate to advanced hobbyists - but that doesn't mean beginners should be deterred for getting involved.
Similar to building an engine or other multi-component assembly, "book knowledge" only takes a hobbyist so far. When the rubber meets the road, final performance is the sum of knowledge and experience. I have a generic understanding of internal combustion engines and am comfortable under the hood of my vehicles, but there is no way I would attempt to build my own performance engine.
Experience is the costliest part of progressing from beginner to intermediate to advanced and expert levels, because there is no substitute for lessons learned thru trial-and-error - or as a student under guidance of a leaned teacher. The school-of-hard-knocks has a way of teaching hands and minds nuance that can't be conveyed in text form. When it comes to sound, the lessons never end, even for professionals.
In a complex assembly of components like an audio system, achieving excellent system performance begins with knowledge of many elements. On the speaker side of a system, a basic understanding of Thiele-Small parameters, impedance, mass, resistance and laundry list of other parameters. From there mounting location, reflection, diffraction, baffle composition, phase relationships, ETC enter the mix. There are equations to serve as starting points for those things, but it's only thru experimentation that intuition of what works best/where/under what conditions is developed
IMO: a casual hobbyist is wise to purchase a quality pre-packaged two way system for their project. By doing so, most application specific design parameters are solved and they'll end up with a good sounding system.
On the other hand, if a casual hobbyist is interested in taking on a challenge - and wants to test/fine tune their understanding of how things work, experimenting is a fun and rewarding effort. After all, unlike a first time engine built, it's not like a speaker system will cause catastrophic failure if done *wrong*. A guy might burn an amp channel or fry a voice coil, but his vehicle isn't gonna burst into flames because he mis-wired a crossover - so from that perspective, experimenting is fun.
If you've read this far, perhaps this will be helpful:
The LPG's you asked about are interesting. I'm not familiar with them but that doesn't mean a damned thing. One thing is absolutely true in sound - NO ONE can tell you what sounds good. They can only impart what sounds good to them. Your ears may agree or disagree with others, but like seasoning on food, every human has their preference.
ALU domes are known to be brilliant performers. These have very low moving mass which *should* translate to excellent transient response. @ 92db/1W, they are efficient, and with a resonant freq of 1,850, should be solid down to 2.5kHz or so. With those things in mind, you *could* insert a 11uF cap in-line, giving you a first order filter @3.5kHz. That would result in a 6db down point almost exactly @ resonant frequency. Depending on your listening habits, that may be pushing the lower limits of this tweet. As an alternative a 10uF cap would raise the x-over point to 4kHz which would be safer for more enthusiastic listening levels. Some sound guys will spew endlessly about the horrors of 1st order filtering. To them I say: PFFFT! Your ears might disagree with me on that - or not.
Better still, a second order filter @ 3kHz would change their sound tremendously, then the 12db down point would be almost directly in line with resonant freq, probably resulting in a warming low treble while maintaining ALU brilliance. But now we are talking about a cap and coil, so things get a bit more complex from a wiring and installation perspective.
Don't forget, there are assembled crossovers that can do everything needed. The biggest "problem" with most of those is: they aren't necessarily intended to be used in a mobile environment, but as long as there is space, they do the job.
As you can see, these are good reasons to consider purchasing an pre-packaged/pre-engineered two way speaker system.
Best of luck in your quest.
