Btw, does anyone have an idea what is the chronological order of the MM code? Did Honda publish anything regarding that, or there's only empirical data?
There has never been a distance-based maintenance schedule for any Ridgeline. Honda says nothing other than "follow the Maintenance Minder", so we can only go by owner reports.
Honda says the engine oil and transmission fluid life are calculated based on actual driving conditions. The other maintenance items are aligned with the nearest oil change.
Based on observations the "average" driver will see the following (+/- a few thousand miles):
A1 (engine oil, tire rotation) at about 8,500 miles.
B16 (engine oil, oil filter, tire rotation, rear differential fluid) at about 17,000 miles.
A12 (engine oil, tire rotation, engine/cabin air filters) at about 25,500 miles.
B1 (engine oil, oil filter, tire rotation) at about 34,000 miles.
A136 (engine oil, tire rotation, transmission/transfer fluid, differential fluid) at about 42,500 miles.
B12 (engine oil, oil filter, tire rotation, engine/cabin air filters) at about 51,000 miles.
(This information is based on my observations of owning five Ridgelines, the reports of
@silkiechicken, and other members of this forum.)
Keep in mind that not every owner will see this exact sequence since it varies based on actual driving conditions and when the maintenance is performed.
Honda says to change the rear differential fluid at 7,500 then every 15,000 and the timing belt every 60,000 under specific, "severe" conditions. They also say to change the engine and cabin air filters every 15,000 under specific "dirty" conditions. Otherwise, "follow the Maintenance Minder".
Individual Maintenance Minder codes can be reset by a Honda dealer using their scan tool. For example, if the transmission fluid is replaced before prompted by the Maintenance Minder due to a repair, the transmission fluid life can be reset while leaving the other maintenance items including the engine oil life unchanged to keep the Maintenance Minder in sync with actual maintenance needs.
