1 - 5 of 5 Posts
I have 2012 ridgeline.
After reading many repair threads regarding map lights, I’m looking for further suggestions.
Interior driver map light not working. Homelink works, passenger light works. Switched bulbs. Switched switches . Cleaned ,lubricated both sets of contacts. Replaced both switches , bent threads. Replaced both bulbs. Both working . Reassembled. Reinstalled. Drivers side works, passenger not. Homelink works. Fuse ok. I’m guessing Wiring harness or assembly. Non-dealer Suggestions?
2022 RTL-E Crystal Black Pearl
If you have a multi-meter (volt meter), check to see if you are getting power to the bulb connections.
Reactions: speedlever
Sounds like the problem is switching sides. Has to be a contact issue. Although some or all of the tricks you've tried have always rescued my Pilot and Ridgeline, who share this common trait.
Years ago I put some cheap LEDs in my Ridgeline interior lights. The map lights are flaky now and have been for a while. I need to address the issue. Again. When I get a round tu it.
Reactions: securityguy
Discussion Starter · #5 ·
thanks. I replaced w/incandescent, then led Andrew cleaning contacts.
1 - 5 of 5 Posts
