1 - 9 of 9 Posts
Hello ROC,
I had to take time off from Iraq and go on a road trip when i got home. The first thing i did was try to adjust the mirrors and they did not work(yes i moved the left and right switch) :) . I looked in the book for the fuse and it is not listed, and the light for the heated mirrors does not work. Can some one tell me where the fuse is? Thank you
Was the car on? I am pretty sure that the mirrors in the Ridgeline do not work when the car is off unlike other Hondas. They also don't work in Accessory mode. I may be thinking of the wrong car, but I know one of them is like this and they are both Hondas so maybe it is both.
Discussion Starter · #5 ·
Fuse 30 was not blown. I called the dealer today and talked to the service department, the mechanic said that he was not that familiar with the Ridgline and i would have to take it in and have it looked at.
Hello ROC!!!
Heater right mirror not working , is there a fuse for the heater mirrors?
Where is it located?
Thank you.
Also I suspect that the reason is not the fuse.
But, I wonder if there is any heat fuses and where are they?
INGMAR, as per a post upthread, #30 in the underdash fuse box controls the side mirrors.
1 - 9 of 9 Posts
