Been playing around with various raw and assembled LEDs for a while now. Borrowing the idea from Ford, I installed the stainless fixtures seen in the middle on the underside of the exterior rear view mirrors.
There's plenty of how to mirror removal/mod info on the ROC, so this ain't no "how to" post, just the results.
If I had it to do over again (and I will), I'd move these to the outer most portion of the mirror, away from reflections on the door skin.
In the images above, the light emitted by the black fixture is MUCH more pleasing, with a natural-ish yellow tint. But even mounted on the bottom of the mirror, I couldn't handle the cosmetics. They were likely made for a specific application/installation, hence the recessed groove. Tried filling it with an O-Ring but... ah... no.
Anyhoo, these are mighty bright. Like obnoxiously bright. And there is glared from the door, but if you wanna see whats on the ground, you will.
Next time the door panels come of, these will get moved to the outer edge.
In the meantime, they are wired to power at the rear console/back seat passenger feat. I like having the vehicle let me know where it is in a dark lot, lighting up the ground around her, but they MIGHT be times you don't want to advertise so brightly.
True of all LEDs, these things are hyper-current efficient. The combo of rear seat and both exterior mirror LEDs require less than half the current demanded by the single incandescent bulb that used to light the rear passenger floor.
I've already experimented with tint. No bueno. Will play with a resistor or two to tone down the overwhelming eye ball piercing pure white light from these little devils.
https://www.oznium.com/
