Yesterday I was out in Mojave Desert, CA and had the pleasure of a little dirt and sand...along with the dry salt flats. Well what can I tell you…?
The departure and approach angles are OK for most for the trails and dirt roads but the ground clearance leaves a little to be desired. This is to be expected and as we know very few actually take them off road. Drive on the top/crests of the ruts and keep in mind that the clearance is only 8 inches.
The traction from the 4wd was very good. The Ridgeline climbed fairly steep dirt and gravel short hills (climbing out of the sandy washes) with no slipping. Going over the sandy washes was not a problem. I did not need to hit the dash button and was very pleased with the traction.
As we know the frame is stiff and on more than one occasion one wheel was off of the ground. This was not a problem because of the 4wd.
On the way out of the desert I had a load in the bed that weighed 1200 lbs and the truck was able to handle the undulating freeway hills at 65-75 without the engine going over 3800 rpm. Handling was fine with the load but I would not want to carry any more weight in the bed.
Overall a very satisfied customer.
