1 - 1 of 1 Posts
I have a 2008 Ridgeline. This problem I noticed yesterday morning, but the problems seem to be mostly centered around the multi-control level to the left of the steering wheel. The high beams will not turn on. Both bulbs are good. Also, the windshield wipers will only operate in low. Mist, high, or interval will not work, nor will the washer. Both turn signals do work however. Other problems that have happened at the same time but not centered on the lever are the headlight indicator light does not come on even though the headlights are on. Also, while I can remotely lock/unlock the vehicle, the security will not set. I've checked the fuses and they seem to be fine.
any thoughts?
1 - 1 of 1 Posts
