Cost me $90 to build, probably can be done for less if you can find the fork locks cheap.
Started with a 55" piece of extruded aluminum. I put it across the two tie-down hooks just under the rear window.
I fastened it down by sandwiching the hook with a bolt and an aluminum plate.
Bolted the Fork Lock to the beam. And thats it.
This is the simplest way I could think of, It takes two bolts to remove, and the bike fits with the tailgate up!
