Should be same as 2016 Pilot and many other Honda/Acura vehicles.
I can't understand why some pitch a fit about the Ridgeline having a timing belt and the related maintenance cost of that service. If they had a Accord or any other Honda/Acura that has a timing belt it would be about the same.
I had my 2000 Acura 3.2 TL Timing Belt replaced just like the 2007 Ridgeline.
But I have seen post on here and other forums that bash the Ridgeline for having a timing belt. I am sure other manufactures have maintenance related things on their trucks that the Ridgeline may not have done as often.
Not you having a fit just in general some here & other forums bash the Ridgeline. I was just wondering if it was something bad by having a timing belt. My 1980 Honda Prelude had one I had it replaced way back when.not having a fit... just a question and comment.
My previous accord and current Acura uses the K series 4cyl with the timing chain.
Is 105K the required change interval on the Gen 1 RL timing belt? Been a while since I owned a vehicle with a belt. Many manufacturers that once used belts, are switching over/or already moved to chains again (Toyota, Subaru, Hyundai, Suzuki, etc). My 1st Gen Tacoma had a chain and I experienced no issues putting 200K miles on it.Some see it as a negative in that it will cost you $600-$1000 to replace every 105k miles. Others see it as a benefit of having a "like new" engine every 105k rather than dealing with a tired engine due to a stretched belt.
Haha that's like asking for a discount cause the tires will need replacing...Or is he deducting that from what he's willing to pay for the truck...
Have to agree with you. Just looking at the other 2016 trucks closest to the RL2:I'm sorry, utter BS for a truck to have a belt.
you would think that since ALL Honda engines are interference engines they would use a chain, since ALL Belts must be changed at about 100K and chains last the life of vehicle. I know, belts are lighter...According to this list, most Honda engines use timing belts. But some of the 4 cylinder engines use a timing chain. I note the Civic moved to a chain beginning in 2006.
2008 to 2014 Accord V6 3.5 – Belt
2008 to 2014 Odyssey pilot and Ridgeline V6 3.5 -Belt
2006 to 2007 Accord V6 3.0 – Belt
2006 to 2016 Civic – Chain
2005 Accord 3.0 – Belt
2003 to 2011 Element – Chain
2003 to 2016 CR-V – Chain
2003 to 2004 Accord 3.0 – Belt
2003 to 2016 Accord – 2.4 – Chain
2003 to 2004 Odyssey and Pilot V6 3.5 – Belt
2002 Civic 1.7 – Belt
2002 Accord 2.3 – Belt
2002 Accord 3.0 – Belt
2002 Passport 3.2 – Belt
2002 Odyssey 3.5 – Belt
2001 Civic 1.7 – Belt
2001 CRV 2.0 – Belt
2001 Prelude 2.2 – Belt
2001 2.3 Accord – Belt
2001 Passport 3.2 – Belt
2001 Odyssey 3.5 – Belt
1999 to 2000 Civic 1.6 – Belt
1999 to 2000 CRV 2.0 – Belt
1999 to 2000 Prelude 2.2 – Belt
1999 to 2000 Accord 2.3 – Belt
1999 to 2000 Passport 3.2 – Belt
1999 to 2000 Odyssey 3.5 – belt
1998 Civic 1.6 – Belt
1998 CRV 2.0 – Belt
1998 Prelude 2.2 – Belt
1998 Odyssey and accord 2.3 – Belt
1998 Accord 3.0 – Belt
1998 Passport 3.2 – Belt
1997 Civic 1.6 – Belt
1997 Del sol 1.6 – Belt
1997 CRV 2.0- Belt
1997 Accord 2.2 – Belt
1997 Odyssey 2.2 – Belt
1997 Prelude 2.2 – Belt
1997 Accord 2.7 – Belt
1997 passport 3.2 – Belt
1996 Civic 1.6 – Belt
1996 Del sol 1.6 – Belt
1996 Accord 2.2 – Belt
1996 Odyssey 2.2 – Belt
1996 Prelude 2.2 – Belt
1996 Prelude 2.3 – Belt
1996 passport 2.6 – Belt
1996 Accord 2.7 – Belt
1996 Passport 3.2 – Belt
Honda Timing Belt and Timing Chain List - Your Car Angel - Your Car Angel
A belt will need to be changed at regular intervals (usually at 90-120k miles) whereas a chain is generally good for the life of the engine and does not require maintenance. As a side note ALL Honda engines are interference engines. There are no Honda engines that are non-interference. - See more at: Honda Timing Belt and Timing Chain List - Your Car Angel - Your Car Angel
You can find some very destroyed Saturn engines (not the model that used a Honda engine ironically), which all had a timing chain, due to chain guides failing. Chains aren't bullet proof either.... they require guides and when they wear they become loose, can become noisey etc. etc.you would think that since ALL Honda engines are interference engines they would use a chain, since ALL Belts must be changed at about 100K and chains last the life of vehicle. I know, belts are lighter...
I agree.I'm pro Honda and G2 RL, but...
I'm sorry, utter BS for a truck to have a belt. No other truck does...well one other (see below). Heck, few cars do anymore either. Big upside is the chain in my 2.4 Element.
At least the belt on the diesel Canyon/Colorado has a 150,000 interval and is there on the front of the engine where you can get to it without gobs of needed labor. This is a HUGE downside to the Ridgeline that only a Honda nutswinger would want to justify.
Not gladly. Begrudgingly.I agree.
If timing belts were so awesome other trucks would be using them too. Honda knows the fanboys will buy & gladly pay $800 to $1,200 for the Timing Belt service.
