So I just purchased a nice 2012 RTL. This is my second Ridgeline and I had it back at the dealer for vibration at idle, which was a bad motor mount, and the wind at the windshield issue.
My question is some of the vibration is gone, but it is still present. I opened the engine compartment with the truck running, and the engine is excessive rocking/shaking. Its idilling fine, just the engine is shaking way more then normal. We took a look at my wifes 07 odyssey, and a newer pilot , and you can barely tell the engine is running.
Can someone confirm that the engine should barely be shaking. Could multiple mounts be bad, tranny and motor.
The other issue is the windshield its is better, but its more pronounced at the drivers pillar then it was before or the same. Kind of hard to tell. Although on portions of the ride it seemed much more quiet? My question is will it be a bigger problem if they try to fix it with a windshield replacement. I feel they should be able to eliminate the noise to a lesser degree.
Enjoying the truck and really like it but the vibration in the steering wheel is unaccetable and I feel it can be fixed. the wind noise I'm still wondering about that issue. Any thoughts.
This is my second Ridgeline, and I never had any vibration or wind issues on my 2008.
