2006 Honda Ridgeline RTL w/Navagation
I have been using the voice controlled automatic climate control. On the first cold day since I bought the truck (used), I tried the heat out. It was 30 degrees outside and after 45 miles the cabin wasn't warm. I had a mechanic check things out. The passenger side & rear vents are blowing hot, but the drivers side is cold.
The air conditioning works fine in all vents.
What could the problem be?
The mechanic was going to try to swap out the temp sensor first...
