When's the last time you changed fluid . And are you using Honda tranny fluid?
Use Honda antifreeze. Honda DW1 transmission fluid. Honda VTM4 rear differential fluid.I have checked all hoses and radiator. See no leaks. Fluid is just slightly low in reservoir. Only thing I see a possibility of one hose clamp is rusted but no wetness around it
What's a good type of anti-freeze to put in it ?
No offense intended Gerthebear, but... it is not a good idea to spray "lubricant" onto the serpentine belt (perhaps you just meant water).OK so it shouldn't be the transmission. Maybe try spraying the alternator belt and pulleys with a lubricant and test for the noise again. If the noise persists try test after turning on and off the ac and listen for a change in the noise. If there is a noise change chances are the problem is something connected to alternator belt. So a pulley or belt. Let us know your results.
