As was stated in an earlier post, you need to install a new battery. This will solve your problem with all the warning lights coming on (even though the truck is running fine).
If you can get the Honda Fluids in Norway...I would recommend that you replace the Honda VTM4 fluid in the rear differential, also the transmission fluid (use Honda DW1). Also, replace the gear oil in the transfer assembly.
You should have the power steering fluid checked/replaced, and the brake fluid replaced.
If the truck has 60 thousand miles or more on it, replace the coolant.
Someone else will reply with recommendations about OBD II scanners and diagnostic software, I'm sure.
But, replace that BATTERY! That will solve your immediate problems.
