Hey guys, I want to get the factory installed unit with XM to replace my stock sport one. Is it plug and play, what else besides an antenna do I need? Thanks in advance.
'Bunch o' stuff required. Not sure this is practical when pitted against the option of an aftermarket unit.
FYI, the OEM XM receiver is positioned behind the rear seat, and connects to the head unit via wire harness from there to the front. OEM antenna is roof mounted "bump" on center rear of roof.
XM OEM unit is available through HandA.com. As Dnick commented there's lots of stuff to this. The XM unit is $229 from HandA. I've attached the installation instructions. Looking at this I decided to install a USASpec Aux Input and run an XM aftermarket unit.
