Be careful using oil analysis labs/services that don't do proper interpretation of the data, sadly a good interpretation is lacking. On the larger part of this board a member shared a BKlabs report with two intervals.
1) the first interval the unit had high fuels dilute and very high insolubles reading. This affected his results and nothing was addressed.
2) second interval was better but because the Bklabs product has NO FTIR work , no accurate fuels dilution reading, and still had terribly high insolubles for the engine design, especially in 5000 miles, they focused on lower wear reading. The whole point of testing is to use it as ACTIONABLE DATA not a view that no one understands.
Suggestions:
Use a lab that has FTIR capability to get combustion dynamic readings ( among others) or you are a few steps behind using oil analysis as a good warning method to tighten up the engine burn and operating characteristics.
Use a lab that offers gas chromatography tuned for gasoline fuels instead of inaccurate flash testing.
Use a lab that offers Karl Fischer water reading so you get a accurate titration of water and 02 H bonds.
Use a lab that it recently certified to ISO 17025 spec so the data is standardized.
DO NOT expect the lab to interpret the data for your application accurately since the "lab dorks" won't know proprietary metallurgy and materials used in the engine or understand the operation of that engine. Knowing testing, chemistry, and OEM designs is rare and hard to put together.
For 40+ years I worked independent oil and fuels data and was a chem engineer for a major OEM. Dr Haas is not a tribologist or a chem engineer. He's a smart guy and sincere but risks drawing incorrect conclusions without the proprietary knowledge of all the aspects of lubes analysis.
The science and art of lubricants and fuels testing is variable in the field so be careful being mislead by those that want to sell you something. I am retired and share this only to help guide a satisfactory experience and not waste your time or $$ on testing.
Suggestions:
