Oil Catch Can
61340 Views 182 Replies 25 Participants Last post by  AnSchmidt
I recently bought a Dodge Challenger w/ the 5.7L Hemi and there is some debate on an owner's forum about the need for an oil catch can. The can traps oil before it gets into the intake air system and prevents coking in the engine. This issue occurs as a result of the design of direct injection engines. While there has been plenty of debate about the cylinder management system and VCMuzzler in the ROC forum, I've seen nothing about a catch can despite the 2G also having direct injection. I'm curious as to why no mention here. Different design, different priorities, or another reason this hasn't come up? Would the 2G benefit from a catch can?
Interestingly enough the Challenger forum barely mentions the cylinder management system which shuts off 4 cylinders under light load conditions. Apparently it caused issues in Chrysler vehicles years ago but those problems are now resolved.
1 - 20 of 183 Posts
The only time I heard of a ( catch can) was when talking to my son about his 1.8T VW. Some kind of a good thing for turbo cars.
You're right that catch cans are used on turbo engines. Their use is apparently spreading.
I've seen it mentioned on here a couple times. The catch cans dont seem to get a lot of love here.
I think one reason for that is because many Honda buyers just arent into modding the powertrain as much as, say, the Big3 drivers. Honda buyers tend to value the peace-of-mind of not having to mess with the powertrain. And for good reason, as Honda powertrains, over the long haul, have had a tendency to be more reliable than your average bear.
OTOH, in efforts to make more efficient powertrains, it seems Honda may be sacrificing some of their reliability. This was proven out in the previous-gen VCM.
The jury is still out on the current VCM, as well as direct injection on the Honda V6. As with the VCMuzzler, a catch can would serve as an insurance policy, of sorts. You may never need it, but if done correctly, it may prove beneficial over the long haul.
Would I get a catch can? I dunno. I believe there is merit and benefit in having a catch can, but then I also have to justify it to my wife. Then she will ask, "why are we buying a Honda if we can't trust it?". Then I will have to explain the "lesser of many evils" thing, and who knows how many other cans of worms....in that light, it is probably not worth it.
Reactions: 2
Lots of Tacoma owners install them, check out this thread for some good pics: https://www.tacomaworld.com/threads/oil-catch-can-install-guide.231227/
Don't know if the RLII would benefit.
Catch cans are a sound and proven technology. You don't see them as oem because they require ongoing maintenance, and no oem is going to release a product like that in this day and age (look how hard they fought DEF on the diesel vehicles) - one of their number one market g ploys is zero-maintenance, or ultra-low maintenance for 100k miles.
Also, they are an additional expense that the oem does not want to cover/warranty or pass on to their consumer.
This is why we have the aftermarket.
Reactions: 2
I had an EcoBoost ( Twin turbo ) in my F-150 and the catch can worked great. Not needed unless you are turbocharged.
I owned a 2015 Dodge Durango with a 5.7L engine. I used a catch can and was amazed at how much oil actually collected in the can that would have gone on to be burned in the cylinders. As everyone knows, burned oil isn't a pretty sight. Just imagine how it looks on your engine's internal parts. People who say such things are a waste of time or simply dismiss them without research should think twice.
The design of the Honda engine fuel management in my opinion solves the issue pitched by those who sell catch cans. The 3.5L has a Direct Injection system that sprays fuel into the combustion chamber using injectors that have 6 ports creating a pattern that will hit the backside of the intake valves while they are still open. It then has a second injection of fuel later in the compression stroke after all valves are closed for combustion. That first injection event will clean the intake valves of any residue that may be created by PCV fumes if any.
By following several forums and advice from several manufacturers and highly skilled mechanics, I believe the best practice for an owner of Direct Injection engines is to use a Top Tier gasoline for cleaning of the combustion chambers including valves and minimization of combustion residue contributing to carbon creation. Additionally using Full Synthetic motor oil with changes at 3-5K will insure the engine is clean internally for all of the complex valve mechanisms and minimization of carbon creation created by dinosaur oil during the combustion process.
All of the hype about catch cans can be traced to those who sell them and their often lengthy and repetitious infomercials on auto forums. They will often reroute PCV flows just to attach their catch cans which will likely void some of the engine warranty.
The worth of a catch can isn't based solely on the type of vehicle you drive or what size/type of engine it is, it's also directly due to how hard you drive it. If you have a naturally aspirated, port-injected Toyota Corolla that never sees 4000+RPM, a catch can is nearly worthless. If you auto-cross a direct-injected, supercharged Corvette Z06, you'd be VERY foolish not to run a catch can. Here's a few types of vehicles that can benefit from one:
- Turbo/Supercharged vehicles. More cylinder pressure means more oil that will come up through the PCV system. That will coat the insides of the air intake tubing and the intercooler before returning to the crankcase. A catch can prevents this from happening.
- Direct-Injected vehicles. Because the air/fuel mixture never touches the rear of the intake valves, the oil residue can't be burned away.
- High-horsepower V8/V10/V12 engines that are driven hard. More cylinders means more cylinder blow-by means more oil residue. Even with port injection, a catch can is a good idea.
- Diesel engines. Diesels are naturally direct-injected. Although they create less crankcase pressure, catch cans have their worth.
Obviously, there have been many advancements in technology which lessen or eliminate the need for catch cans in some vehicles. You may never have an issue if you own a vehicle with one or more of the above qualities, but having that extra protection isn't going to hurt anything (as long as you remember to empty it every now and then). If you're easily daily-driving your Gen1 RL (total port injection), you have nothing to worry about. As for Gen2's, I believe Honda employs a combination of direct- and port-injection that nearly eliminates the problem of carbon build-up on the intake valves. Someone with more knowledge on them can confirm, but a catch can shouldn't be needed for regular use. If you're drag racing your Gen 2 RL every weekend, well... that's different. And foolish.
Cars used short distance clog the pcv. Regardless of engine tech.
Happen on wifey' Volvo driven 4 miles ew daily. Solution is to use it on longer drives in place of my car. That way it heats up and burns off sludge
Shorter drives are harder on engines for many reasons and this can be one of them. If an engine isn't allowed to fully warm up (allowing the piston rings to expand and seal against the cylinder walls) and is driven at even moderately higher RPMs (above 3000 or so), blow by will be more prevalent and quite a bit of oil can be picked up by the PCV.
I only drive 4 miles to work each way, as well, but I have a 20-mile trip 2-3 times per week to get the truck fully warmed up. My process every time I start the truck is to start it, let it idle for about 20-30 seconds to ensure the oil begins to circulate and then start driving. I don't let it get above 2500RPM or so for at least the first 5 miles of driving on my longer trip days and never above 3000RPM on my short trip days. This is the best balance of getting the truck warmed up as quickly as possible while not taxing the engine too much. Once it's warmed up properly, I let it rip to WOT on the highway at least once a week to "blow out the carbon", if you will.
I have one on a Roush Mustang which is supercharged. You'd be surprised at how much blowback oil it catches. The car didn't come with one so I'm not convinced that it's a must have and I'm sure that it'll run fine without it.
Personally, I wouldn't spend the money again. It's a pain to empty as it sits under a strut tower brace.
This is a perfect example of where a catch can is useful. High performance, boosted vehicle that likely sees some higher RPMs regularly. Then again, I believe it's got port injection, so it can likely handle a decent amount of oil through the PCV system without much issue. Nonetheless, you're certainly not hurting anything by having one.
Reactions: 1
When a vehicle owner has decided a catch can is needed, be aware there are vendors who will sell a catch can that may not compliment the PCV system engineered by the manufacturer. There are several instances I have seen on other forums where the vendor has advised of changes to PCV flow just so they can create a manner in which to attach their cans.
In addition, the manufacturer warranty may be compromised by installation of a modification to the PCV system. Can vendors will defend their installations as enhancements to the PCV system, but the reality is the true enhancement is to the vendor bottom-line.
I have not reviewed the details of the Honda Warranty, but I do know the Ford Power-train Warranty explicitly states modifications to the PCV system are not allowed.
Buyer beware.
"Not hurting anything by having one" was meant to be directed towards the mechanical operation of the engine and not stating there are no warranty implications. Most who are into modifying their performance cars even on a moderate level aren't all that concerned with warranties anyways.
I agree a catch can can be good for turbos - just trying to hear as many sides as possible. But why only good for turbos?
A dealer might try to void the warranty because a catch can was installed, but they would have to prove the can caused the problem to make it stick. In my case the dealer has agreed to install the catch can & multiple service people are in agreement there are no warranty issues.
Reactions: 1
If you add port injection to your engine, it should alleviate the need for a catch can. This is the reason I wouldn't put one on my truck.
Anything you can do to stop oil from entering the intake manifold will help. Doesn't matter if it is DGI, MPFI, TBI or carburated. PCV is emissions BS and even though we need it to pass vehicle testing, there is no need for oil consumption through it. Newer engines probably won't be as suseptable to oil consumption as older ones. That being said, if you see oil in the PCV tube going into your intake..... it's not good for your PGM-FI system.
I use closed/inline catch cans on all of my cars. The vented ones are only for Boosted applications. Naturally aspirated setups need to be a closed system in order for the PCV system to work properly.
1 - 20 of 183 Posts
