What kind of oil did they top it off with out of curiosity? Just synthetic 0-20?
We have a Subaru which makes engines renowned for burning oil. That said, we have a 2016 model forester... at 6k oil change intervals of 0-20 synthetic, it does not burn any noticeable oil for it's first or second oil changes (which we do ourselves). Meanwhile, my 24 year old inline 6, with 200k miles, which has had a headgasget job due to an overheat, which has subsquently failed... burns nearly a quart per 3k, and leaks about a gallon of coolant in the same time span. lolIf I was a half quart low on that many miles running oil with the viscosity of water I'd be not concerned at all. Maybe that's old school logic.
If you can make it 5k miles without being a full quart low I say good to go.
I have a 2017 Ridgeline that I got in Sept 2016. It now has 28,000 miles on it, mostly highway. Only used it for moving heavy loads a couple times and when doing so, have driven it gently. Since it hit about 18,000 miles last summer, it has been going through a quart of oil every 4000 miles. Getting a quart of oil into it is a pain in the tits: there is nowhere enough room to maneuver a plastic bottle around without spilling it all over the front of the engine. Today, I removed the plastic fashion-accessory cover - the one that says "Honda Earth Dreams I-VTEC" on it - from the top of the engine, thinking I'd have more room to get the oil into the fill neck. It had been secured with 4 rubber grommets on 4 plastic posts. Unless you line the cover up perfectly when you are re-installing it, the grommets push through the plastic assemblies that hold them and find a way to disappear into the recesses of the engine compartment.I checked the oil level yesterday with 4500 miles and I was 1/2 quart low on oil. The Honda dealer confirmed it was low and added oil. Additionally, they advised me to wait until it was down to 15% before change oil.
Has anyone else had this issue with their 2017 Ridgeline?
Disabled mine too, no oil consumption since it has been in place. About a 1000 miles on it now since the 1st oil change. Did put 0w20 Full Syn in there. Mighty thin at that viscosity.I don't care what anyone claims. Oil usage is not normal. If it were normal then why don't all similar vehicles use oil? As other's have posted, it's most likely caused by the VCM (that Honda claims they updated to eliminate oil consumption). As I have written previously, I visit a local Honda dealer regularly and Honda is still having issues with VCM. I disabled mine. Zero oil consumption in 15k miles.
I have to give the level a check from when I changed it a month ago, but that cover is in the basement now. Not worth the hassle. I don't think it does a thing about engine noise and was just a way to beautify the engine compartment.I have a 2017 Ridgeline that I got in Sept 2016. It now has 28,000 miles on it, mostly highway. Only used it for moving heavy loads a couple times and when doing so, have driven it gently. Since it hit about 18,000 miles last summer, it has been going through a quart of oil every 4000 miles. Getting a quart of oil into it is a pain in the tits: there is nowhere enough room to maneuver a plastic bottle around without spilling it all over the front of the engine. Today, I removed the plastic fashion-accessory cover - the one that says "Honda Earth Dreams I-VTEC" on it - from the top of the engine, thinking I'd have more room to get the oil into the fill neck. It had been secured with 4 rubber grommets on 4 plastic posts. Unless you line the cover up perfectly when you are re-installing it, the grommets push through the plastic assemblies that hold them and find a way to disappear into the recesses of the engine compartment.
Anyone else going through oil at that rate?
