Oil Filter Deflector
7231 Views 7 Replies 6 Participants Last post by  larryr
Yeah these pictures suck I'll admit... No doubt this mod has been posted here but I'm a new Ridgeline owner so I figure why no post it. Same BS as my K24's the filter can't help but pee on the subframe, this is my first pro-type. I'll snap some HD pics this week on the 2nd version. All-in-all it didn't spill a drop on the subframe...
Reactions: 2
1 - 8 of 8 Posts
Nice job Bross, I've done different things hadn't thought to make something semi perminate maybe a pic looking up from the bottom. Were you able to use existing holes or tap new
Here is my 2nd oil filter deflector attempt. I used 28G galvanized steel and two small magnets at the bottom to hold the funnel in place. I will probably use some HondaBond in the corners just for extra precautions. Carsmak it's meant to be used only during oil changes. I used cardboard the first time but having to hold it in place while it drips sucks.
Floor Flooring
Floor Paper Flooring
Metalworking hand tool Cutting tool Tool Tool accessory
Auto part Muffler Metal
Metal
Auto part Floor Metal
Reactions: 1
I made similar with a 5 Qt oil bottle & a stanley knive (cut half off skinny-wise the whole middle & lower section (left top full width). It just tucks up in there when I do the filter. You DO have to leave the lid on the bottle, LOL. Works fine.
I've had pretty good luck putting a shop towel across the frame below the filter and using a quart sized freezer ziplock baggie around the filter.
I am hoping that this tool will come to market soon. If not, I may try to fashion something similar.
I just use a used priority mail box that is about 10 inches log and form a U around the filter - the oil leaks down the cardboard and I dispose of the cardboard with the paper towels I clean up after.
We always seem to have two or three boxes in the recycle bin. I used to use a half gallon milk jug with the bottom and sides cut out to guide the oil but after watching the mechanics at the honda dealer use cardboard, went that way too.
1 - 8 of 8 Posts
