rear main seal leak, use search to find several threads on issue
I believe this thread is the one Speed might be referring to (I just remember "pesky" for this one & it's easy to find LOL.Jon, there are some case bolts which have also been a source of leaks.. much easier and cheaper to fix than a rear main seal.
Let me see if I can find the thread about that....
Thank you for the tip and the link. But aren't these bolts visible from the outside of the engine? My leak is definitively coming from inside the flywheel lid.I believe this thread is the one Speed might be referring to (I just remember "pesky" for this one & it's easy to find LOL.
http://www.ridgelineownersclub.com/forums/showthread.php?t=94930&highlight=peculiar+oil+leak
This would be a thousand percent better if it's your cause (compared to main seal). Good Luck.
