Oil Pressure sender location
13309 Views 5 Replies 4 Participants Last post by  jaymer
Would someone have a diagram of the oil sender unit location ?
Any idea of the thread size of the oil pressure sensor plug-in ?
1 - 6 of 6 Posts
2
oil pressure switch
Good. That helps. So apparently by firewall and same side as oil filter. Will have to figure out the thread size later. Thank you.
2
why is there 2 oil sending unit images that are different. 1st gen 2007 ridgeline
I can't tell exactly where these are located. I know mine is accessible when the right front tire is off - is supposed to be visible there.
I would assume thats this 1st image... but where's the 2nd image located?
400821
vs.
400822
I believe the first image is the VTEC oil pressure sensor. The engine oil pressure sensor is right behind it.
See the expanded image here and the attached pic. The engine oil pressure sensor is hiding behind the VTEC sensor in my pic.... which was taken to highlight the engine block drain which is above and to the left of the engine oil pressure sensor.
400836
400837
400838
Both can be found in the FSM on pages 8-5 and 11-261.
Auto part Engine Vehicle Fuel line Car
Text Line art Font Design Line
Line art White Text Joint Organism
Reactions: 2
1 - 6 of 6 Posts
