Does anyone have a hitch-mount personal plow on their Ridgeline? I have a 300 ft hilly driveway and it's a pain to clear even with a snowblower. I was thinking it would be easy if I could push the snow out to the street since I live at the end of a wooded cul-de-sac.
I was thinking of getting a Curt front hitch:
http://www.hitchsource.com/honda-ri...p-27806.html?gclid=CN2b5qjXp7MCFUlxQgodVkcAhA
and a Snowsport LT blade:
http://www.hitchcorner.com/snowsport_snow_plow.htm
The Snowsport LT is only 82" wide and weighs 56 lbs, or about half of a regular 7' personal plow blade. The light weight blade shouldn't cause any problems if I leave it mounted all winter long right? I never considered a plow before since most personal plow setups weigh over 200 lbs, but this setup only weighs 85 lbs for the receiver and blade. No electronics or angler involved since it's self-adjusting.
What about the effects of pushing vs towing? Is pushing 3500 lbs of snow the same as towing 3500 lbs of snow? I planned on just making 2 passes down the middle of the driveway, then using the snowblower to do cleanup work along the edge of the driveway so the snowbanks don't get too high. What do you guys think?
