I too recently have used a "Blue Tooth" toy called "
Fixd" on my 06' RTL Ridgeline to which it also threw up this code:
P2646
Rocker Arm Oil Pressure Switch Circuit Low Voltage"
It was able to gather the following diagnostic information on February 3rd, 2018:
Calculated engine load: 32.9 %
Engine coolant temperature: 177.8 F
Short term fuel trim—Bank 1: 9.38 %
Long term fuel trim—Bank 1: 1.56 %
Short term fuel trim—Bank 2: 5.47 %
Long term fuel trim—Bank 2: 0.0 %
Intake manifold absolute pressure: 33 kPa
Engine RPM: 4638.0 rpm
Vehicle speed: 52.79 mph
Timing advance: 35.0 degrees
Intake air temperature: 60.8 F
Throttle position: 26.3 %
Relative throttle position: 20.0 %
It also gives the following additional info via the app:
A rocker arm is a lever that is used to open your engine's intake and exhaust valves. Certain engines can use the rocker arms to vary how much the valves open allows the engine to make more power at higher RPMs. If the actuators that control these rocker arms are not functioning properly, the engine may not make as much power as it could or the engine could run poorly."
I'm not exactly sure what to do at this point (not a mechanic, I'm in IT... but I'd like to pretend I like to know what the heck I'm doing).
While the above info
Skelley521 provided sounds easy to review, I'm not exactly sure what all needs to be preformed other then performing an Oil Pressure Switch Test at this point. I was recently advised by a co-worker whom use to work as a mechanic long ago to clear the code in my Fixd app & to see if it comes back & note when it does. I recently replaced the Oil & Filter back on February 15th, 2018 (mileage then was 181,961) using the recommended 5W-30 (
Mobil 1 High Mileage). I'm currently at 184,964 as it's my commuter for now.
Q: I'm wondering how much damage am I doing to the Ridgeline without getting this properly looked at?
