1 - 20 of 23 Posts
I wanted to show off my painted wheels on my 2011 RTL. I discovered that the wheels were the same as the Sport wheels that came out a few years later. I painted the wheels using VHT High Gloss Epoxy paint. Used a die grinder with a medium pad on the high areas with a final clear coat to protect the areas not painted and WALA, I now have a set a sport wheels at a fraction of the cost. Maybe 50.00 bucks and some change. Check them out.
Thanks
2104 Honda Ridgeline SE
Very Nice. Nice Job!
I so want to do this on my RTL rims!!! How many coats of black paint did you use?
I followed the directions on the can to a T. I started out with light tack coats every 10 minutes for the first 4 coats. Then laid down a heavy wet coat. Actually totally black, they looked awesome.
Looks good, I've been tempted to do the same thing using dark metallic paint rather than black.
Nicely done
Wow, that really looks great! Well done
You did a GREAT Job!!! Happy for you. Worth another $2K on trade in :grin:
My 06 of course has a different set of wheel style. Anyone with OEM 06 Ridge type wheels done anything like this or powder coated a different finish?
Do you have any masking or other prep. techniques you're willing to share?
Discussion Starter #15
Sorry, I somehow missed the post about masking. I did not do anything real special. I mask the valve stem and put washers in the the stud holes to prevent painting the rubber. I used index cards between the rim and the tire. The sweetest thing and what I feel made the painting easy was I set the wheel on a cheap lazy susan so I could spin the wheel as I was painting. This made seeing the whole wheel very easy. You can see the lazy susan under the one picture after painting the wheel black. I then used a die grinder with a medium pad to removed the paint on the high surfaces. Final was a clear coat over the whole wheel.
Looks good! Nice job.
Sent from my iPad using Tapatalk
This is awesome! Did you sand the finish before painting? Did you remove the factory clear with an etching primer?
Sent from my SM-G935V using Tapatalk
Discussion Starter #19
Hello. Sorry for the delay in the reply. I did sand the wheels down using a steel wool. I did not us any primer. If I recall, the VHT does not call for the use of primer. However I did follow the directions on the paint can to a "T". VERY Light coats with 10 minutes between coat. Over an hour in painting. I did the same with the clear coat.
Excuse the dumb question, but what are the reasons why you could not mask off the high parts to avoid using the grinder wheel? I assume it's because the paint would have dried in such way making the tape removal very difficult?
Also, did you paint the inside of the wheel as well? Thanks.
1 - 20 of 23 Posts
