I took the black, plastic engine cover off and think I found the PCV, which I am assuming is the little silver elbow on the front, passenger side of the block, very close to the oil dipstick. There's a black hose that goes from this silver elbow up to the front, passenger side corner of what I think is the intake or valve cover, as it's that big, silver plate at the top of the engine after you remove the black, plastic cover. When I blow into (and suck) the hose when it's connected to the valve cover (or intake?), it flows effortlessly, as expected. However, when I blow into (and suck) the hose when it's connected to what I think is the PCV valve, it also flows pretty effortlessly, BOTH WAYS.
QUESTION #1) Is that okay for a PCV to allow air flow both ways?
This little silver elbow I'm thinking is the PCV valve seems impossible to remove, as it has no visible hex faces, and rotating it to unscrew the whole thing would cause it to turn into the wiring runner for the plugs (which I could remove if necessary). I wonder if this is even the right thing.
QUESTION #2) Is the thing I'm describing really the PCV?
QUESTION #3) So, if I needed to remove (and maybe replace) this PCV valve, how would I do it? Does the thing just thread directly into the top of the head? Does the new valve look like a threaded elbow?
The dealer guys tell me these things never screw up and that I should just leave it alone.
