Wow, nice commute. Thanks^^^Thanks! About 34k, my daily commute is only about 6-miles^^^
Valvoline MaxLife motor oil may be a better 'it can't hurt' solution.I'm a bit hesitant to use a stop leak type additive in the oil. There may be unintended consequences. That being said, I might consider using some Sea Foam just prior to an oil change.
Good for you. Had the same issue crop up in 2014 around about 111K miles. My mechanic pulled the bolt and sealed it. Charged me $30. Haven't had a problem since. He may have mentioned there was a bulletin on it, but I don't remember.Update - Bottom of engine is still dry, no leak whatsoever.![]()
Has anyone done this procedure on their own? Removed a main bearing cap side bolt, seal it and re-install? I have one leaking right above the oil drain plug, I can get a wrench on it but right behind it is the drive shaft so not sure how much room I have to remove the bolt. Wondering I should just have the dealer fix it instead of messing with it in the driveway.
Is it safe to assume you ruled out the rear main seal?
Have you ruled out coolant?
And of course, the main bearing side cap bolts that this thread is about?
Can you elaborate on your no loss of fluid comment above (except for the PS fluid?). What's up with the PS fluid leak?
You might find some of these references useful:I think I made some progress as far as the smell with some extra help.
The oil leaking near the black plate cover does not smell the same as the power steering fluid, both having a not very strong smell that can create some confusion
The one from the oil dipstick smells sntronger like gas, the one from the leak I'm trying to identify has a different smell than all of them but matches the color to the one on the dipstick.
It looks like it is going to be the motor oil. Minutes after washed my hand and ate pasta salad, I went to the garage and opened a quart of oil that had some left. I smelled it and it did not have the gas smell, from the dipstick, my memory is not accurate but I can assure that It may be similar to the one from the leak. My bad, never rely on matching the oil dipstick smell.
My question, if I remove the black plate cover at the bottom, will I be able to see if it's the rear seal leaking?
That's the bolt.Are one of these bolts directly above the oil pan straight up from the drain bolt? I believe I have a leak there because there is oil around the rim of the oil pan above the drain bolt.
Awesome. Happy to hear of a leak that's a free fix with materials on hand!!That's the bolt.
Sent from my Pixel XL using Tapatalk
An advisement, I haven't seen many forums with steps involved but if you have any questions let me know. If it's the same one on the engine block as mine was, you'll have to take out the axle to be able to take the bolt out and seal it. Easy enough I did it in a day but needed a trip to the shop for CV grease and a new strap for the CV boot because mine came off lol. Good luck and God bless.Awesome. Happy to hear of a leak that's a free fix with materials on hand!!
Oh no! haha, I thought I could just pop it off. It's the one closest to the timing belt. I can crawl underneath and see it.An advisement, I haven't seen many forums with steps involved but if you have any questions let me know. If it's the same one on the engine block as mine was, you'll have to take out the axle to be able to take the bolt out and seal it. Easy enough I did it in a day but needed a trip to the shop for CV grease and a new strap for the CV boot because mine came off lol. Good luck and God bless.
