Oh, wouldn't that be sweet! But I don't think that much wasted copper in the harness would get past any good bean-counter.I wonder if there is the plug for the inverter in the wire harness on a RTL-T just waiting to be plugged in?
If you don't want to mess with wiring to get a 12V outlet in the bed, you could use a 12V plug adapter for the seven-pin trailer harness. I use one on my Gen1 and it works great!.
Hmmm, the AC/DC inverter is in the cab, no wonder I couldn't find a 12V. power wire out in the bed location. I wonder if there is the plug for the inverter in the wire harness on a RTL-T just waiting to be plugged in? Do you know if the bottom two wires/plug (red & black) are the power in?
Pop the trim panels off below the rear seat drivers side and you should be able to see them if they are there.I have the RTL and it does not have the inverter. I wonder if there is 12v wiring behind where the inverter would fit?
Does anyone know if there is a 12v wiring harness back there? I'd love to tap into it and add some Anderson Power Poles to the RTL pocket to make it super useful.
I also see this is an old thread, but wouldn't have noticed it without you're reply pushing it up. Indeed, cool photos. It's exciting to know it is in the cab (I'm surprised it's not as close to the battery as possible) just for the possibility of an in-cab outlet. Does this mean that the non-featured models do have a plug in the harness? Or do you need to splice?i know it's an old thread, but thanks for posting the pictures. I just hope my power inverter fits in that spot.
You're very welcome and thank you for commenting.Thanks for the adapter idea. I have a small 12v pump attached to a 15 gal water tank that use to water plants at a adopt a spot and was wondering how I was going to connect the wires from the 12 volt motor to the Ridgeline battery due to the negative terminal being covered with the air duct without taking the duct off. this will work just fine. Just one question? How do you keep power on to the plug. Is it when you turn on the lights? Thanks
