Has anyone put a Pioneer TS-SWX2502 10 inch flat preloaded sub under the back seat?
Link here:
http://www.crutchfield.com/p_130TSX2502/Pioneer-TS-SWX2502.html
I cut a 12x6 blank to check fit and it looks like it'll be tight but it should fit.
Thanks in advance!
Yes it will fit, the seat's legs that fold, will press against the front side of the box, not sure if the boxe's legs will be on the way, or may rest properly against the plastic panel edge where the seat's legs lock, if you tilt the box a bit it may work.
Worse case you cut or remove the front and rear legs, and move just the front ones 1" in, that way they rest against the panel while the seat legs will hold the box or prevent the box from moving forward.
I can tell you that a 12" wide piece of wood, seats flat on the top of the panel and rests on the carpet flat and the seat folds and locks with no issues. I did this for an amp rack and to place a box with an 8" sub.
Another option would be get a piece of wood 22" long by 12" wide, place it flat under the seat resting the panel and carpet flat, place the sub box on the top of the wood, and done, removing th boxe's legs is an option, the sub box is not going anywhere held and pressed by the seats, legs. If go off road and jump maybe it will move, some L brackets and screws attached to the wood and sub will secure it even more, but being so heavy, there is no good chance it will slide to the opposite side.
Hey once you verify it fits, simply mark the wood where the legs will sit, pre drill the holes and put one screw on each leg. This is another option to consider if you don't want to remove the boxe's legs.
Post pictures once you are done
