1 - 4 of 4 Posts
that will be pretty close. If you look around on here, there are some posts on making a box that is almost an exact replica of the factory box with some dimensions listed. I have the factory box in my garage and I will try to give you some measurements tomorrow so you can compare before making the purchase.
Nope it will not fit. The top of the OEM box has to be no wider than 4" and this one is over 5"
no more than 4 inches deep ok but this box looks like it has little extensions so it can be mounted under a seat to downfire if you were to cut them off you think it would fit? thanks again for the help
1 - 4 of 4 Posts
