This whole thing is sad, as Chrysler has had their "multi displacement system" out since 2005 with none of these issues. Had it on my '05 Hemi Magnum with zero issues in 100,000 miles, and none of the folks on LX forums did.
I guess not everyone has had the same experience.This whole thing is sad, as Chrysler has had their "multi displacement system" out since 2005 with none of these issues. Had it on my '05 Hemi Magnum with zero issues in 100,000 miles, and none of the folks on LX forums did.
That's kind of what I was thinking might be the case. My sensors just need calibrating I guess. :act024:I thought my comment came across as more sarcastic ... ....
Exactly! Don't engineer to the test; forgetting that the ultimate test is how durable your vehicles are perceived to be. The consumer will never notice 1mpg but will remember thousands of dollars in repairs over the long run.There's a lesson to be learned there.. if you can't build it right don't build it!
Did you even read that post? Problem wasn't MDS related. But yes, some did override it just because they didn't like the idea or it screwed with their exhaust note with straight pipes.I guess not everyone has had the same experience.
http://dodgeforum.com/forum/3rd-gen-ram-tech/144539-multi-displacement-system-override.html
I don't think many would care unless it caused a problem. But I do remember assorted things being bypassed on cars for similar reasons. Don't get me wrong, I ran across a few others too mentioning MDS but nothing the magnitude of displeased Honda owners.Did you even read that post? Problem wasn't MDS related. But yes, some did override it just because they didn't like the idea or it screwed with their exhaust note with straight pipes.
I'm not disputing your statement, but I'm curious as to how much your Camaro weighs. In my experience weight and number of gears have more effect on mpg than (gas) engine size, straight 6, V6 or V8.I think it is possible to engineer a truck with improved MPG and not use VCM. VCM is a cop-out in my opinion. They have it on the shelf, so they are using it. Unless Honda found a way to hit 30 mpg with this truck, I will not be interested in VCM. I'm not buying the tradeoff of mechanical wear to fuel savings.
I have a 1996 Camaro that has been modified to road race. When it was stock it had a 5.7L V8 engine, 275 hp, and got 26-27 mpg on the highway with a 6 speed manual tranny. The mpg speaks to aerodynamics and factory engine tuning. No VCM.
In race form, the car has a 6.2L engine, 425hp (to the wheels), and the same aero and has a highly modified racing tune. It gets 25mpg on the highway. No VCM.
Honda can do it. They don't need VCM. And with the small numbers of RL sales expected, 1 or 2 mpg on the RL will have little to no effect on the corporate CAFE.
Well you live in Florida, you need an optinal 2 wheel drive RL that you can modify for your needs. Just ask for it and see what Santa brings you just like the off road version some of us want. Some of us have been naughty and aint going to see it, another words take what is offered or move on. Im sure the new RL will be some bad ass shopping truck.I think it is possible to engineer a truck with improved MPG and not use VCM. VCM is a cop-out in my opinion. They have it on the shelf, so they are using it. Unless Honda found a way to hit 30 mpg with this truck, I will not be interested in VCM. I'm not buying the tradeoff of mechanical wear to fuel savings.
3650 LBS with driver. The 6 speed is stock which has two (2) overdrive gears. It also has 315 series tires on it (huge). Stock rear. I realize 3650 is a lightweight by comparison to a Ridgeline, but the Camaro also has excellent aero as opposed to a sheetmetal brick floating through the air .I'm not disputing your statement, but I'm curious as to how much your Camaro weighs. In my experience weight and number of gears have more effect on mpg than (gas) engine size, straight 6, V6 or V8.
I would agree with you except I'm one of those odd Floridians that actually needs 4wd. I am a real estate appraiser and find myself in the woods quite often. Then there is the towing boats and pulling them out on slick ramps side of things as well.Well you live in Florida, you need an optinal 2 wheel drive RL that you can modify for your needs. Just ask for it and see what Santa brings you just like the off road version some of us want. Some of us have been naughty and aint going to see it, another words take what is offered or move on. Im sure the new RL will be some bad ass shopping truck.
Edit: sorry off track, NO VCM for me.
Drop it into sand mode. I'm just kidding. Actually my gen 1 with heavy loads where I'm from could do it well. I never have used Honda At-4 lock system in that application when required. I have used it on a ramp but that was more for curiosity, I wasn't stuck. Not on stock tires either, BFG K2I would agree with you except I'm one of those odd Floridians that actually needs 4wd. I am a real estate appraiser and find myself in the woods quite often. Then there is the towing boats and pulling them out on slick ramps side of things as well.
I'll be most curious about your impressions when you have 117k miles on it. While Honda may have been able to make VCM operation transparent, I have serious concerns about the complexity of the system as well as the reliability of the engine over the long haul. The high oil consumption issue as well as engine rebuilds on (too) many VCM engines is pretty alarming.I don't yet know whether the current VCM is good or bad but for the record, the current VCM that was introduced in the 2013 Accord is not the same as the first gen one that is being discussed so much here. So far at about 17k miles on my 2014 Accord it has been flawless.
I'm with Speed. Let's remember also that the RL weighs in about 1000lbs more than Accord with what amounts to the same engine. VCM may not be so seamless with an extra 1000lbs to push around.I'll be most curious about your impressions when you have 117k miles on it. While Honda may have been able to make VCM operation transparent, I have serious concerns about the complexity of the system as well as the reliability of the engine over the long haul. The high oil consumption issue as well as engine rebuilds on (too) many VCM engines is pretty alarming.
If you don't keep a vehicle past 100k miles, you're probably ok. But for those of us who run them until they are no longer economical to maintain (most likely several hundred thousand miles), VCM is another matter altogether.
And by default, those issues are THE reason to avoid VCM. IMNSHO.Engine repairs and longevity are another matter entirely and would be the ONLY reason to avoid the technology (in its latest iterations) IMHO.
