Identify components that have failed or had replaced on your G1 Ridgeline
1 - 15 of 15 Posts
2006 Ridgeline w/ 148K miles
Identify components that have failed or had replaced on your G1 Ridgeline. Excludes maintenance items (belts, brakes, wipers, etc...)
First pass represent items that i had to replace/ repair on my G1.
More than happy to add new items to the list. - just include those in the comments.
2012 Ridge steering cable was binding, replaced after warranty expired as a good will gesture. My drivers side window regulator is weak in cold weather but still working. That's it.
2014 Sport
For the GenI you should also have:
motor mounts, rear seat pulleys, sway bar end links, sway bar bushings, front struts, rear shocks, body panel rust, interior leaks, torque convertor judder (separate from outright transmission failure), cylinder 4/5 sparkplug hole / casting failures (separate from outright engine failure), rear main seal leakage, ignition key cylinder failure, brake rotor "warpage" . . .
Discussion Starter #8
Added items until i ran out of available entries...
2011 RTL
Passenger front CV axle, slight vibration before lift. Awful vibration after lift. Driver front is next with slight vibration after lift
The only reason I replaced the PS pump was the system ran dry after hitting a Raccoon and tearing the feed line off. I'm on my second battery as well.
2011 VP Bali Blue Pearl
Starter was replaced before I purchased. I put on a new serpentine belt.
1 - 15 of 15 Posts
