That's a great TIP. I have a moisture meter I use in woodworking.I bought the Harbor freight moisture tester and checked my 17' over the weekend. Read out with pins jammed into carpet was 0%. I think I'm good for now.
Thank You
If it’s reading 0%, it’s likely not down far enough. I have to push the meter down and compress the insulation essentially to get any reading. I have to do that with the pins and the sensor settings.I bought the Harbor freight moisture tester and checked my 17' over the weekend. Read out with pins jammed into carpet was 0%. I think I'm good for now.
Would add that this type of leak will originate closer to where the rear seatbelts and rear seat frame bolts to the floor. My last leak episode was wet on the vertical padding, but relatively dry on the horizontal floor padding. Also the carpet can feel bone dry while the underpad is wet. So your likely best path is the 2 plastic panels covering the seat frame bolts, not via the door thresholds.It's easy enough to pop off the bracket (for the seat track) that runs across the width of the second row to gain better access to check for water.
I hope they do it right. Even large auto glass companies have very little experience replacing rear windows on a niche-market vehicle like the Ridgeline.At least Honda approved the dealer doing the teardown and a respected local auto glass company doing the install, so there is hope.
That is my concern as well.I hope they do it right. Even large auto glass companies have very little experience replacing rear windows on a niche-market vehicle like the Ridgeline.
While I had it, it probably only seems like that in this echo chamber.It appears from the posts that "They all do this".
I believe that this is the first time we've seen this theory (although I didn't go back and re-read the entire reply chain.) But, I would give this idea some credence since it sounds like the tech really wanted to solve the mystery rather than just 'get it out the door.'... According to service guy, the tech had a bit of a personal vendetta against my leak because he couldn't figure out where it was coming from. They ended up sealing every unsealed seam, and re-sealing others. I guess they just repeatedly ran the truck through the carwash to verify it was still leaking. They settled on the culprit being a couple bolts in the rail system on the top of the cab. ...
There have been reported leaks at the roof rail and at the brake light trim fasteners above the rear window. These typically show up as wet headliners or leaks running down the rear glass. I guess it’s possible, if the truck is sitting at the right angle, for a leak to run down the c pillar and onto the rear floor without showing other leak symptoms.I believe that this is the first time we've seen this theory (although I didn't go back and re-read the entire reply chain.) But, I would give this idea some credence since it sounds like the tech really wanted to solve the mystery rather than just 'get it out the door.'
So, the saga will continue. After Honda sent the entire back glass to the dealer and they had their favorite glass guys come over, they said it is too involved and will need to go to a local body shop for the glass install.That is my concern as well.
I'm liking the theory less and less.There have been reported leaks at the roof rail and at the brake light trim fasteners above the rear window. These typically show up as wet headliners or leaks running down the rear glass. I guess it’s possible, if the truck is sitting at the right angle, for a leak to run down the c pillar and onto the rear floor without showing other leak symptoms.
EvanM, LouP here, While you have the L/R oval plug exposed, why not just seal it and after seal cures, continue with your paper towel test. In my case, I had driven several miles in heavy rain and pretty flooded/puddled road.I'm liking the theory less and less.
I said I was going to wait for the two replacement parts to come in before I would inundate my truck. Nature had other plans, and we got a steady rain all morning. Not the torrential downpours we had before, but enough that I thought I should check under the sill plates.
The passenger side felt damp to me, but it might have been in my head. I mean... it's still raining out. I could take some moisture in there with me. I wiped my hands before sticking them in there, but who knows. It was enough to get me motivated, so I pulled off the plastic trim and carpet under the rear driver-side seat, and the wall just above the wet spot was bone dry. Then I pulled the plate from the floor that locks the rear seat support (and carpet) in. Feeling underneath, there is a distinctly wet spot right over the plug that Loup (page 17 of this thread) identified as one of the sources of his leak. But here's the thing... I haven't driven anywhere in rain since I got the truck back. There is no way in hell rain was splashing up from the driveway through that plug. Something else is going on.
I left all the trim off and put a couple layers of blue shop towel between the carpet and that plug. I'll check it when the rain stops (it's supposed to rain on and off all weekend) and see how wet it gets.
So, turns out I was a bit mistaken. I went back around 2:30pm and was surprised to find the paper towel over that plug was dry, and there was a puddle of water slightly further back. It must be dripping down from somewhere, but dripping clean enough it's not leaving a wet spot on the back wall. The plug didn't really make much sense... the truck has been sitting on a flat gravel driveway all day.EvanM, LouP here, While you have the L/R oval plug exposed, why not just seal it and after seal cures, continue with your paper towel test. In my case, I had driven several miles in heavy rain and pretty flooded/puddled road.
Again in my case, I had removed ALL the plastic trim, floor door sills, and the ones across the rear panels under the folded seat and I was able to feel around that back panel and there was no evidence at all of damp carpet/sponge padding.
OK, you're within warranty and lemon law is excellent and it sounds like you have a Dealership that wants to help.So, turns out I was a bit mistaken. I went back around 2:30pm and was surprised to find the paper towel over that plug was dry, and there was a puddle of water slightly further back. It must be dripping down from somewhere, but dripping clean enough it's not leaving a wet spot on the back wall. The plug didn't really make much sense... the truck has been sitting on a flat gravel driveway all day.
I called Honda just to update my service guy, and he says he's going to escalate the issue there to his manager, who he thinks will involve a regional supervisor. This is somewhat complicated by the fact that I didn't buy from this Honda dealership, but I have mostly kept my salesman from the other dealership in the loop as well.
As far as sealing the plugs: I don't truly have everything exposed- the rear seats are still in, so all that carpet it still looped through the back wall. My approach so far has been to inspect but not repair. I know others disagree here, and to each his own. For myself: I don't work for free, especially not doing work I have already paid for, but also this way there is no chance any of this can come back on me or anything I have done to the truck. I'm still under factory warranty and lemon mileages. If it were otherwise, I'm sure I would be thinking about trying to keep the truck dry at all costs.
Hey, you know what- I forgot that I did ask! And the service guy even mentioned at one point that they took pictures of everything. I'll have to get what I can from him.PLEASE consider asking them to take pictures of the inspection area and repair.
