In Pa they get three attempts at the same repair. Then we get to petition for a buyback. (minus a bunch of money)
I would...it's not hard to do. Plus you can look for any other possible issues...Hello all. Newbie here. I’m right in the middle of trying to decide between a 2020 Ridgeline Sport AWD with 2800 miles on it and a new 2021 Ranger. The RL wins the practicality test hands down. But I somehow stumbled across this whole leak issue and it’s a bit terrifying. Should I bring this thing home for an overnight test drive and saturate the rear window/front bed area to see what happens??
Or, skip the charm and just tell them you won't consider buying it until you are sure that this well-known water leakage issue is not present. If they start hemming and hawing, then you have the answer.Shouldn't be too hard to do while they are away checking on something. If you've never done any kind of interior work and aren't comfortable popping the sill panel then you'll just have to be extra charming and get them to do it for you.![]()
After all that pain and an angst, my Ridgeline is dry and I enjoy it immensely. I though about getting a lawyer for lemon law but honestly. even though it was service 4 times and for 85 days. it didn't meet the NY guidelines for a Lemon Law case, primarily because the problem got fixed on service number 3. Service number 4 was to fix body damage incurred when someone at the dealer drove under a car lift that was a bit too low! By the way, the body work was excellent.I read through a lot of your posts last night about the issues you had. Did you end up getting rid of your Ridgeline? Would you tell others to avoid getting one?
I'd skip both the Ridgeline and the Ranger and sit tight.I have some inside pull at this dealer. Shouldn’t be an issue to take it home overnight or at least keep it for a day.
Not sure if this matters but it is not at a Honda dealer.
Thanks so much. Glad you are still enjoying your Ridgeline.After all that pain and an angst, my Ridgeline is dry and I enjoy it immensely. I though about getting a lawyer for lemon law but honestly. even though it was service 4 times and for 85 days. it didn't meet the NY guidelines for a Lemon Law case, primarily because the problem got fixed on service number 3. Service number 4 was to fix body damage incurred when someone at the dealer drove under a car lift that was a bit too low! By the way, the body work was excellent.
The long service times were due to a combination of things but parts ( like new carpets) were hard to come by at times. I had the carpets replaced all three times.
Finally, even if I got my money back, there were no RTL-Es available at least in the color I had and would want.
I could have gone to court to sue for loss of use blah blah blah but I just wanted it all behind me.
Will I keep my 2020 as long as I did my Gen 1? Maybe, maybe not. Let's see how it holds up. I got the the Ridgeline primarily for the trunk. That may sound silly but it is one of the best features in addition to the ride. It may not be the meanest truck,haul the biggest load or work out for a contractor but for my needs it is an great fit. As I get older, many of the newer safety features are a big plus. I love the adaptive cruise control, I use it all the time. I rarely used cruise control on my Gen1. So far, the blind spot warning system has saved my a*s several timesThe heated steering wheel is wonderful for folks like me who suffer from circulation problems
Yes, there are things I don't like but there were things like that on the Gen1.
All in all, I am pleased.
I would take it overnight to check for leaks. It's a 10-minute task to lift the rear door sill plates & carpet to check. Make sure to get drainage (in quantity) through the drain slots near the lower corners of the rear window. It's also helpful to ensure the front end of the truck is slightly downhill if possible so drainage follows the back of the cab as opposed to the headboard of the bed. After talking with dealership service people, also want to run water over the top of the cab to check if anything is migrating downward through the upper rear window & surrounding frame area.Hello all. Newbie here. I’m right in the middle of trying to decide between a 2020 Ridgeline Sport AWD with 2800 miles on it and a new 2021 Ranger. The RL wins the practicality test hands down. But I somehow stumbled across this whole leak issue and it’s a bit terrifying. Should I bring this thing home for an overnight test drive and saturate the rear window/front bed area to see what happens??
educated? like taught to flip burgers yesterday!Welcome to the u-boat club. Yours sounds like the classic body seam sealing issue on the passenger side. My water was in the middle and Honda says it's a leaking window. It's in the shop still awaiting corporate approval for the repairs.
You are very right about how you might never know it's leaking based on the carpet itself....that foam backing keeps it from wicking up. I would encourage every G2 RL owner to take the time and feel under the carpet...whomever is applying sealant at the plant needs to be "educated".
What is the dealer asking for this used RL? 2021 Sports seem to available and are going for ~$34K. Not sure if any 2020s are left, but If you can find a leftover new 2020, it will be about $32K.Hello all. Newbie here. I’m right in the middle of trying to decide between a 2020 Ridgeline Sport AWD with 2800 miles on it and a new 2021 Ranger. The RL wins the practicality test hands down. But I somehow stumbled across this whole leak issue and it’s a bit terrifying. Should I bring this thing home for an overnight test drive and saturate the rear window/front bed area to see what happens??
Yes, those are the drain slots. I just caulked mine shut yesterday hoping to minimize the chances of water draining down the cab wall while waiting for a permanent repair...View attachment 413299
Is this the drain area you are referring to?
It is priced at 37K but I’d be giving about 34 for it before TTT and trade.
1. Ask yourself why someone (present company excluded) would trade in a vehicle that's less than 18 months old and has only 2,800 miles. Maybe they had problems and dumped it. A vehicle that's at least 6 months old with only 2,800 miles? Maybe it spent a lot of time in the shop to have been driven so little.
It was sold in Nov of 2020 to a 70 year old man. The salesman told me why he traded it in but I don’t remember. I’ll have to ask again. I do know he traded it for a Colorado.
@zroger73 glares at @Starquesbd22 for several minutes with absolutely no emotional expression whatsoever from across the room.Repeated on the passenger side and…reached into soaked foam.
First, I got to thank you Starquesbd22 for because of you I now know how easily the sill plates pop off in the rear! What did I find, after two years of Oregon winter rains and a dozen or more washings, it was reassuring to find that with our 2019 RTL was bone dry as far as I could reach under the carpet on both sides!Started by pulling the driver side rear sill plate and running my hand under the carpet…dry as a bone. Repeated on the passenger side and…reached into soaked foam.
