Hello. Proud owner of 2017 Sport. Put about 2000km since I got it.
However, I can't listen to anything but the radio because sound quality from any other source is just awful.
PROBELM-Bass and treble way too prominent and mid-range almost not there, except when listening to radio.
DESCRIPTION: at factory defaults (sub, bass, treble all at "0") the bass actually shakes the truck when the music is up. The most prominent sounds in any rock song are the repetitive "tss, tss, tss" of the highhat (treble) and the thumping of the bass drum and guitar. Vocal and every other instrument are there, but nearly lost. Even when stereo is turned down to the level that i can just barely hear the song, the main things I hear are those highs and lows.
(Failed) SOLUTION ATTEMPTS:
-Tweaks via LCD screen to bass, treble, and sub provide some minor relief from peircing and pounding, but also flatten the midrange greatly
-Multiple sources tried including: iPhone and 2 different android phones, using both Bluetooth and auxiliary for each. I have also adjust the output settings on each phone and uses multiple music apps
-Ipod using auxiliary
-Usb key directly to stereo
-Android auto
The weird thing is the radio sounds fine.
QUESTIONS:
1) any ideas?
2) whenever I connect to android auto (via usb) the Bluetooth on my phone must be on. Do you know ow if it is playing music via Bluetooth or via the cable?
3) do you know what compression format the Bluetooth player in the car uses? Is it lossless?
Thanks!
