1 - 3 of 3 Posts
The manual suggests we rotate our Michilen tires every 7500 miles (and I think HAL has a chip in it that gives us a service due notice when this occurs). The manual also tells us that there are two ways to rotate depending on the type of tire - either directional or non-directional.
I checked a tire forum since I did not know what type of tire we had. It appears from the feedback I received that our tires are non-directional. If this is indeed the case, according to the manual, we need to rotate the front to back in an "X" pattern, rather than in the directional simple same side front to back.
This is the first time I have ever heard of "directional" and "non-directional" tires. I just want to verify from you all if this information is correct and that the tires we have are indeed "non-directional".
From the Tire Rack
For Honda's recommendation, see page 257 of your owner's manual.
"Directional" tires have special tread patterns that only work properly in one direction. These tires are built in LH & RH patterns.
1 - 3 of 3 Posts
